 Post subject: 3rib best for 1641?
PostPosted: Tue Jan 29, 2008 7:32 pm
I run a car tranny now. How much for a 3rib,cv's,tranny mount and whatever else I would need? Thanks Jason
PostPosted: Tue Jan 29, 2008 7:56 pm
id say for a total swap over you will have roughly between 500-600 for it all. 350 for a good 3 rib id expect to pay. cv's new are 50 a piece axles used are 50 a set usually, plus stubs, boots, etc. mount kits are around 45 bucks last time i checked. you can probably stumble across some good deals on here on axles and cv's though. 3 rib is gunna be your best bet for a 1641, thats what i run and it works well, i suggest going to atleast bus on all 4 cv's i broke car outers.
PostPosted: Tue Jan 29, 2008 8:08 pm
Thanks for the info Jeff.
PostPosted: Tue Jan 29, 2008 9:53 pm
call this guy 300 for 3-ribs 100 or so 4 to axles and 4 joints,bill 662-665-1995,bout 100 dollars for shipping
PostPosted: Wed Jan 30, 2008 9:22 am
I run a 1641 with a 3 rib and love it. I went through about 6 car trans before i finally broke down and went 3 rib. I gave away all my spare car trans and will never own another one. It was like night and day between the two.
PostPosted: Wed Jan 30, 2008 2:39 pm
u shouldnt have give them away if u tear up 1st gear some of the car gear stacks are the same reverse gear to
PostPosted: Wed Jan 30, 2008 3:34 pm
A friend of mine gave me a truck load of them so when I switched to bus I gave the rest of them back. Didn't really want to store them and figured since he gave them to me i would return them and maybe he could get some use out of them. I kept the reverse gears from the ones i blew the spiders out of.
PostPosted: Wed Jan 30, 2008 4:06 pm
http://forum.woodsbuggy.com/viewtopic.php?t=2761
heres a 3 rib 4 sale
PostPosted: Wed Jan 30, 2008 4:44 pm
my cousin ran a three rib with a 1641 progressive carb and he could climb what he wanted to he ran bus to car and never really had troubles with blowin cv's of course his tires didnt really have much tread to bite with either
PostPosted: Wed Jan 30, 2008 8:28 pm
i run a 3 rib with a 2180 and 35" tires and im bus to car on the joints never broke a trans or cv
PostPosted: Wed Jan 30, 2008 9:07 pm
Man wish i could say that . i run a 1641 and tore 4 3 ribs up 1st gear and diffs
PostPosted: Wed Jan 30, 2008 9:12 pm
i run buss to car si i dont break a trany i will by car joints all day i dont want to get a new trany but so far i have been lucky not broke any
PostPosted: Wed Jan 30, 2008 10:06 pm
i run a car thing tranny with bus to car and 2332.
PostPosted: Wed Jan 30, 2008 10:14 pm
backwoods, you run v-treads right? You think they grab to much for car tranny?
PostPosted: Wed Jan 30, 2008 10:18 pm
i run cut v treads with mine. and a superdiff in the thing tranny. i like it because its geared like a 6 rib. i think the 3 rib is geared to low.
almost forgot i also run cutout center gears in my bus joints so there is no binding when the axle is flat. shave out some splines on the bus joint so you can use car axles and still get the clip on. thx greg for that one.
PostPosted: Wed Jan 30, 2008 10:33 pm
[quote='J.DiNapoli']backwoods, you run v-treads right? You think they grab to much for car tranny?[/quote]
Thats what was killing all my spider gears. You can probably run one with v-bars and be ok but i was trying to keep up with all the guys running 1915's and bus trans so I would clutch it like a 2 stroke and could never get a car to last. Once i went to a 3 rib i have not had any problems other than one c.v. Also now i have alot more power on tap because of the lower gears.
 Post subject: 1641
PostPosted: Sat Feb 09, 2008 8:34 am
i got 6 rib with mine runs strong, bus to car, but i do have to climb fast, no crawling for me,
PostPosted: Sun Feb 10, 2008 6:42 pm
Whoever runs car cv`s is a brave man!!
aaron
PostPosted: Sun Feb 10, 2008 11:54 pm
i run a 1915 with a 5 rib bus to car hoping to switch bus to bus after this year when i have extra cash
