PostPosted: Fri May 30, 2014 8:53 am
I just got a buggy that had a 3 speed auto vanagon trans but had no way to cool it. I took the buggy out this past weekend and when I got to the top of some long hills the trans started to slip. I felt the trans and it was HOT. I did some research and found that there is a way to hook up an oil cooler the original oil/water cooler part of the trans. The part that confused me is that the trans that I have does not have thoes ports in it. I am left puzzled on what I could do to add an oil cooler to this trans. As it really needs it.
Here is a link to a pic of the trans.
http://i285.photobucket.com/albums/ll70 ... 161844.jpg
PostPosted: Mon Jun 02, 2014 6:51 pm
The aircooled bus had no cooling provision other than air passing over the tranny. You could add ports to the pan and use a pump and oil cooler though.
PostPosted: Fri Jun 06, 2014 11:39 pm
so just use 2 ports ,an in and an out, in the pan? would that still circulate the cooled fluid though the tranny?
PostPosted: Fri Jun 06, 2014 11:51 pm
Using a pump to circulate the pan fluild through an oil cooler will cool it down. Yes
PostPosted: Sun Jun 08, 2014 12:23 pm
yeah i think thats the route im going to take. thanks?
have you ever heard of one of these trans getting really hot and start slipping?
PostPosted: Sun Jun 08, 2014 4:12 pm
On the vans people would fashion a scoop out of sheet metal to direct more air over the tranny, but that wouldn't work in a buggy.
It probably slipped because it boiled the trans fluid.
PostPosted: Tue Jun 10, 2014 9:03 pm
Would that destroy the fluid? even though the trans is cooled down it still seems to slip. it goes into Park Drive Rev.. fine and moves but it seems when i mash on the throttle it slips instead of grabbin
PostPosted: Wed Jun 11, 2014 12:56 am
I'm not an automatic guy but it sounds like you screwed the pooch on that one.
PostPosted: Wed Jun 11, 2014 5:45 pm
yeahhh i took the pan off and there is some heavy grit in the pan... rebuild time
PostPosted: Fri Jul 04, 2014 6:41 pm
http://akroncanton.craigslist.org/pts/4547817884.html
go get it!~
