It is currently Mon May 04, 2026 9:31 pm
 Post subject: Oil issue
PostPosted: Sun Apr 06, 2014 3:43 pm
Got a new to me 6-rib hooked behind my ecotec , was letting it idle checking fan temps & such , don't have axles in yet & noticed its pumping oil out the vent hole??? What's it's issue??Image. I filled the trans only to the bottom edge of the fill hole on the driver side. It's prob puked out 1/2 quart or more.
ya cant beat fun!
 Post subject: Re: Oil issue
PostPosted: Sun Apr 06, 2014 7:03 pm
EITHER IT'S FOAMING UP OR WATER GOES TO THE BOTTOM AND OIL FLOATS TO THE TOP. MAYBE IT HAD WATER IN IT B4 YOU TOPPED IT OFF. I BOUGHT A TRANS IN FLORIDA ONCE AFTER A HURRICANE AND IT WAS FULL OF SEA WATER FROM BEING SUBMERGED.
PostPosted: Sun Apr 06, 2014 7:52 pm
I would drain and refill. I always install a fitting into the nose cone vent hole to allow me to hook a piece of vacuum line to it. Run the rubber line up higher and never worry about this issue again.
PostPosted: Mon Apr 07, 2014 1:00 am
dont think water is issue. pulled bucket out from under it & oil was clean.what will cause 'foaming'?
ya cant beat fun!
PostPosted: Mon Apr 07, 2014 7:26 pm
Usually just poor quality oil/oil that's far too thick or some moisture in the case for foaming. Or a dodgy aftermarket additive...
PostPosted: Wed Nov 05, 2014 4:32 pm
Found the issue, or rather Tony Begly did. When I told him what it was doing he immediately said the bearing behind the nose cone was going down, said he had seen this several times. Let him fix it & no problems since.
ya cant beat fun!
