| 6rib bellhousing on 3 rib http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=16805 |
| Author: | blackbeauty [ Fri Mar 28, 2014 9:48 am ] |
| Post subject: | 6rib bellhousing on 3 rib |
I have a 6rib in my buggy now and I'm switching to 3 rib for the lower gears but I don't have a 3 rib starter will the bellhousing from 6 fit the 3rib thabks |
| Author: | MickeyMouse [ Fri Mar 28, 2014 11:54 am ] |
| Post subject: | Re: 6rib bellhousing on 3 rib |
I know a lot of people put the 3 rib housing a 6 rib trans but I have never heard of anyone doing the reverse. I would check the input shaft on a 3 rib to make sure it is long enough to work with the 6 rib bell housing. |
| Author: | Jeremy1 [ Fri Mar 28, 2014 7:59 pm ] |
Yes it will work but you need to swap the input shaft. |
