Axles spline question
http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=16758
Author:  Psycho Alpha [ Tue Mar 11, 2014 7:40 pm ]
Post subject:  Axles spline question
Ok guys I need some help.....
I have to order axles and cut them down.
Can anyone tell me how much spline you need on an axle for the CV's?
Author:  Psycho Alpha [ Wed Mar 12, 2014 8:12 am ]
They come with 2.5" splines after I cut them I would have around 1.750". I was told this is not enough but don't stock axle have around an 1". They said 1.750" would pull the CVs apart. I thought that lateral movement or plunge was in the CV not the axle?
Author:  MadMike [ Wed Mar 12, 2014 12:15 pm ]
Post subject:  Re: Axles spline question
The plunge is both in the CV and the splines. I do not have any stock axles here Someone else is going to have to answer that question.
Author:  RaceBugg1098 [ Wed Mar 12, 2014 12:53 pm ]
are they bus or 930? if your buying them new, just buy the correct size. I think they come in 1/2" increments.
Author:  Psycho Alpha [ Wed Mar 12, 2014 3:41 pm ]
930
Measuring it, I need 19.625 to 19.750 and closest I see are 19.250 or 20.250
Author:  Psycho Alpha [ Wed Mar 12, 2014 3:54 pm ]
Thanks Mike
Does this sound right.... If I measure the distance cup to stud when the closest to farthest point and have under the 1.75 that the splines meas. I should be good?
Author:  MadMike [ Wed Mar 12, 2014 4:40 pm ]
Measure center of cup to center of cup when both are perfectly in line with one another. Then subtract whatever they recommend now, a quarter of an inch I think.
Author:  RaceBugg1098 [ Thu Mar 13, 2014 12:38 pm ]
x2!!
