PostPosted: Mon Nov 18, 2013 10:11 pm
I am wondering if a Subaru Trans would be more reliable than an 091. Since the Trans is made to bolt to an engine with 250HP, you would think it would have to stronger.
By the time you get an 091, buy a super diff and weddle gears.. you would have spent the same on a Subaru Trans.
What are your thoughts..
PostPosted: Mon Nov 18, 2013 10:14 pm
How big is the r@p. That is the biggest weak link I think. And also what about gearing can you get one feared down far enough for what we do
PostPosted: Tue Nov 19, 2013 12:04 am
It looks like you can get different gear sets depending on the make and model of the donor vehicle.
As for the R&P, you can get 4.11, 4.44 or 4.86.
Another benefit, the engine gets raised up 2 inches and you can actually use reverse.
PostPosted: Tue Nov 19, 2013 8:11 am
The strongest Subaru trans you can get is out of an 04 STI that is the trans most of the rally cars use,
As far as a regular Subaru trans I'm on # 2 in my WRX
PostPosted: Tue Nov 19, 2013 12:57 pm
lets not forget about it going the wrong way! I know someone makes a reverse cut ring and pinion for it, but now your just dumping money into it like an 091. Not saying its a bad idea or anything, I would love to hear how it works
PostPosted: Tue Nov 19, 2013 3:55 pm
We just need to climb the hills in reverse. :shock: :shock: :shock:
I agree, the reverse R&P is another $1500. At the end of the day, you can get a beefed up 091 or a working Subaru for around the same price.... does a working Subaru work better than a beefed up 091???
PostPosted: Wed Nov 20, 2013 11:42 am
Consider leaving the motor in front of the tranny and use babychains
PostPosted: Wed Nov 20, 2013 2:56 pm
Sounds like a good project for someone that has a lot of experience with Subarus and Babychains :shock: :twisted: :twisted: :shock:
Anyone know someone like that???? Someone that needs to get back in a buggy and start having some fun again???
PostPosted: Thu Nov 21, 2013 5:35 pm
Get busy Marty ! You have a itch yet ??
PostPosted: Thu Nov 21, 2013 9:02 pm
Here is Marty showing what a Subaru V6 with baby chains can do...
PostPosted: Fri Nov 22, 2013 8:08 am
Im am currently working on installing a 2001 subaru 2.5L engine and TRANSMISSION into a 1991 vanagon for a customer. I complete reverse ring and pinion was bought from subarugears.com
I can tell you one thing. These trannys are extremely easy to work on they come apart in halves. One side of the case comes off and all the gears stay in the other half.
Also Subarugears.com is working on an adapter plate to go to and ecotec motor for those of us that have alot invested into those engines.
PostPosted: Fri Nov 22, 2013 8:23 am
The subaru R&P is smaller then the 091. But has a hypoid gear design.
Here is alot of info from wikipedia on gears and specifically the "Hypoid" gear setup.
http://en.wikipedia.org/wiki/Spiral_bevel_gear#Hypoid_gears
A hypoid gear is stronger setup.
Weddle makes custom gear seats just like the 091
http://www.woodsbuggy.com/index.php?option=com_jfusion&Itemid=109&jfile=viewtopic.php&f=17&t=16345
PostPosted: Fri Nov 22, 2013 11:40 am
That is awesome and exactly the info I was looking for. Thanks.. I am currently working with SubaruGears for the reverse R&P but they have not release the 4.86 yet.
I am also talking to them about becoming a sponsor for the site but I want to make sure their products work Off Road before I add them to the site.
PostPosted: Fri Nov 22, 2013 1:37 pm
Yea that's my interest too. If it will hold up off road. But what impressed me is these Trans are all over the junk yards. Also how easy they are to take apart an put together. The 5 speed off road really isn't a big deal I defiantly wouldn't call it a bad thing lol.
PostPosted: Sat Nov 23, 2013 9:09 pm
Very Interesting Video.. A little long but shows a nice breakdown in the Subaru Trans.
PostPosted: Sat Nov 23, 2013 10:17 pm
This one is good too.
http://youtu.be/xSWPKmA09ng
