 Post subject: Starter Bolt
PostPosted: Mon Oct 21, 2013 11:08 pm
Does anyone know if there are two different lengths of starter bolts? I made the switch from a three rib to a six rib tranny and now my starter bolt is too short, any ideas?
 Post subject: Re: Starter Bolt
PostPosted: Mon Oct 21, 2013 11:25 pm
Yes I believe that the 6 rib is different from the 3 rib the 3 rib uses a car style starter the 6 rib bell is longer
PostPosted: Mon Oct 21, 2013 11:48 pm
The 6 rib bellhousing is about 1 inch longer so the starter bolts out of your 3 rib it's definitely not gonna work. And if you are trying to use your 3 rib starter it is also different
PostPosted: Tue Oct 22, 2013 8:29 pm
I got one from an autostick . Its about 1ΒΌ" longer than 3 rib. not sure where your at but your welcome to have it.
