It is currently Mon May 04, 2026 11:46 pm
PostPosted: Mon Oct 14, 2013 6:31 am
Does anyone know what the benefits would be other than the reverse gear being larger of going to a side shift versus a nose shift 6 rib transmission? I am moving from a 3 rib to a 6 rib but want to do it right so I am considering either or to install. Thanks for the help.
PostPosted: Mon Oct 14, 2013 10:51 am
Some side shifts had a super diff from the factory. Also, I believe some have stronger froward gears but I'm not sure.
PostPosted: Mon Oct 14, 2013 1:17 pm
The entire Mid shift trans is stronger than the nosecone 6 rib. The side shift trans is merly a nosecone trans with a side shifter circa up to early 1983. IMHO it's a no brainer to run the 84 and later Midshift for the reverse gear alone.
PostPosted: Mon Oct 14, 2013 9:02 pm
Thanks for the information.
PostPosted: Mon Oct 14, 2013 9:27 pm
The 1st gear on a 3 rib is like 14 mm, 17mm on a 6 rib and 19 on a side shift. I could be off a little. And much bigger ring and pinion teeth.
