6 rib what to do?
http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=16088
Author:  volksdude2010 [ Tue Oct 01, 2013 1:13 am ]
Post subject:  6 rib what to do?
this is third 6 rib thinking all similar problem havent tore into other ones what should i do to fix and prevent from happning again tranny are getting expensive looking for long term fix
sorry in advanced for pic better ones can be seen on photobucket
http://s168.photobucket.com/user/zelien ... t=3&page=1
Author:  Red Barron [ Tue Oct 01, 2013 9:50 am ]
Post subject:  Re: 6 rib what to do?
German Suuuuppppeeerrrr Diff :evil: :mrgreen: :roll:
Author:  lpb [ Tue Oct 01, 2013 10:10 am ]
german :!: .not a floaty :? super diff. :!: chromemoly side cover
Author:  buggybarn [ Tue Oct 01, 2013 2:06 pm ]
Ya exactly what lpb said ! And chromoly side cover . I had a china diff they are junk junk. Junk blew a side screw out of my 6 rib when diff broke ruined everything . 3 hrs of mild riding on tranny .
Author:  volksdude2010 [ Tue Oct 01, 2013 10:41 pm ]
now where to get one and is that the only thing i should do the actuall gears dont look bad but idk i am running a stock subaru to
Author:  PhillipM [ Thu Oct 03, 2013 11:19 am ]
Problem solved:
Author:  aboone993 [ Thu Oct 03, 2013 12:49 pm ]
PhillipM wrote:
Problem solved:
What is that?
Author:  davidk [ Thu Oct 03, 2013 3:27 pm ]
aboone993 wrote:
PhillipM wrote:
Problem solved:
What is that?
X2
Author:  helmetguy [ Thu Oct 03, 2013 5:32 pm ]
x3 come on phillip fill us in!!!
Author:  Psycho Alpha [ Thu Oct 03, 2013 7:50 pm ]
I believe it is a Renault UN5 transaxle out of a van they only have across the pond.
PhillipM wrote:
shadetree wrote:
Wow! The boys at East lynn in WV would love this ride. What is the drivetrain in this machine?
PhillipM wrote:
From a Renault Master commercial van.
RX8 engine + UN5 gearbox.
Author:  Psycho Alpha [ Thu Oct 03, 2013 8:01 pm ]
Question is will it fit in a plastic tote with some pillows?
Author:  hillaholic [ Thu Oct 03, 2013 9:16 pm ]
Haha
Author:  jesse [ Fri Oct 04, 2013 12:03 am ]
i dont know much when it comes to building a trans but if this keeps going on maybe something is not in line right or shimmed correctly or something along them lines
Author:  2800passat [ Fri Oct 04, 2013 12:21 am ]
Lay off the cut brakes til ya get a German 4 diff. And if ya have enough power and ya keep on cut braking doing donuts, your case will crack. Who said that? I said that. Been there , done that several times. lol
Author:  PhillipM [ Fri Oct 04, 2013 9:06 am ]
Someone must have fetched a container full of them over there not long back because I know there's a guy building a Honda powered sand racer over there with one in. The nose is a little longer than the VW but otherwise it pretty much slides in. If you have a long arse on your buggy the long nose won't be an issue, if it is, hook it over the top of the beam.
Author:  volksdude2010 [ Fri Oct 04, 2013 9:21 am ]
as far a shims go how much play is suppose tobe in there cause i have had a lil more then i think you want thats what i was thinking that my axles are sucking them out and causeing them to spin then break but idk ?
Author:  volksdude2010 [ Fri Oct 04, 2013 9:25 am ]
i do use cutting breaks a good bit never thought that would be a problem and if i get the diffs with the 4 spider gears everything will be better and is there any one that sells a complete diff bolt in ready cause as you can see the only thing that looks good is the ring gear i dont want a tempoary fix looking for the permanet one
Author:  2800passat [ Fri Oct 04, 2013 9:28 am ]
just a reminder. U can't use a cut brake if you have a solid diff.
Author:  afterburnt [ Fri Oct 04, 2013 5:36 pm ]
just pm 091 tobin he sells German super diffs for $300 . I just bought one
Author:  hillaholic [ Fri Oct 04, 2013 6:30 pm ]
I just bought a 091 case from him I think. Guy named Tobin from the samba.
Author:  afterburnt [ Fri Oct 04, 2013 8:09 pm ]
he goes by the same name on both sites
Author:  Red Barron [ Fri Oct 04, 2013 8:51 pm ]
Passat he is not welding it or putting in a spool just a good old tried and true super-diff no drink some more beer
