| Puck or Standard Clutch disc?? http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=15836 |
| Author: | Topgun0405 [ Mon Aug 12, 2013 8:57 pm ] |
| Post subject: | Puck or Standard Clutch disc?? |
What's the best for everyday trail riding? Posted using the WoodsBuggy Mobile App |
| Author: | bugman505 [ Mon Aug 12, 2013 9:05 pm ] |
| Post subject: | Re: Puck or Standard Clutch disc?? |
standard all the way. |
| Author: | Topgun0405 [ Mon Aug 12, 2013 9:07 pm ] |
That's what I was thinking I'm running a 4 puck and I have no give what so ever it's either engaged or not I just wanted a little Input to what every one else was running thanks bugman Posted using the WoodsBuggy Mobile App |
| Author: | MickeyMouse [ Mon Aug 12, 2013 9:33 pm ] |
I had to remove my 4 Puck because there was no forgiveness while trail riding. I bought this one from CB performance and I really liked it. http://www.cbperformance.com/ProductDetails.asp?ProductCode=1359 |
| Author: | MadMike [ Mon Aug 12, 2013 9:39 pm ] |
Call Kennedy Engineering and get a stage 2 pressure plate an a organic disc. Puck clutches are either on or off, nothing in between. |
| Author: | gasman [ Mon Aug 12, 2013 9:59 pm ] |
MadMike wrote: Call Kennedy Engineering and get a stage 2 pressure plate an a organic disc. Puck clutches are either on or off, nothing in between. X2, I've had best luck with just a good stock disc. Do not like the pucks for everyday trail riding. Chad |
| Author: | Maddog [ Mon Aug 12, 2013 11:28 pm ] |
Kushlok disk and stage 1 always worked for me. |
| Author: | hillaholic [ Tue Aug 13, 2013 12:30 am ] |
I have a stage 2 with a 6puck. I was slipping a cush lock running the 35's and plumberbill suggested the 6puck. I love it no slipping and it doesn't feel like a puck clutch at all. Posted using the WoodsBuggy Mobile App |
| Author: | jesse [ Tue Aug 13, 2013 1:31 am ] |
i like my stage 1 and 4 puck |
| Author: | wrongwayray [ Tue Aug 13, 2013 5:24 am ] |
Stage. One 6 puck. Can't even tell its a puck disk. Love it. |
| Author: | Odyknuck [ Tue Aug 13, 2013 9:41 am ] |
I have tryed them all. Kennady Stage 1, 2 and now on a 3. I have tryed stock, daiken super clutch, 6 puck and now a combination 8 puck on one side/full organic on the other side. So far stage 3 and the combination clutch is working the best. No slippage and no grabbing. Now to see how well the pair wares. The stock and daiken did not last me a season. The 6 puck grabbed to hard and lasted 1 1/2 seasons. Keep in mind fully loaded my buggy weighs in at around 3000 #s and I am running a Subie Turbo so that has a major bearing on my clutch woes! |
| Author: | aboone993 [ Tue Aug 13, 2013 10:07 am ] |
Ody ...Just curious are you running a 200mm or the larger vanagon 220 (i think) mm flywheel? Posted using the WoodsBuggy Mobile App |
| Author: | Red Barron [ Tue Aug 13, 2013 8:58 pm ] |
I run the 9" flywheel with a stage 1 and a HD cush-lock by Kennedy. The clutch does slip a little but with 243 ftlbs of torque you need a weak link. |
| Author: | bige70chevy [ Tue Aug 13, 2013 9:59 pm ] |
kennedy stage 2 with hd rigid disk...was using cush loc but they got empi cheap quality last time i went to get one so went with the rigid |
| Author: | Odyknuck [ Wed Aug 14, 2013 2:57 pm ] |
aboone993 wrote: Ody ...Just curious are you running a 200mm or the larger vanagon 220 (i think) mm flywheel? Posted using the WoodsBuggy Mobile App I am running the 200MM. When i spoke to Kennady about using the 220MM setup, they stated the cost to switch over was not worth the little gain I would get from it. |
