question
http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=15166
Author:  jesse [ Sat Mar 30, 2013 10:34 pm ]
Post subject:  question
whats the stock first gear i a 456 6rib
Author:  MickeyMouse [ Sat Mar 30, 2013 10:44 pm ]
Post subject:  Re: question
This chart might help but it is for VW Syncro but I believe they are the same.
http://www.syncro.org/FinalDriveRatios.htm
Good Luck.
Author:  davidk [ Sat Mar 30, 2013 10:55 pm ]
All 68-79 bus transmissions have the same 1st, 2nd and 3rd gear ratios.
12. First gears - ratio 3.80 (38/10)
9. Second gears - ratio 2.06 (35/17)
8. Third gears - ratio 1.26 (29/23)
4. Fourth gears - ratio 0.82 (23/28) or 0.89 (27/24)
17. Reverse gears located in the differential half of the case, Similar ratio to 1st gear.
These are the variations in gear ratios for US models:
VIN Reverse gear ratio 4th gear ratio R&P ratio R&P * 4th
218 000000 - 211 2 276560 3.61 0.821 5.375 4.413
211 2 276561 - 213 2 068547 3.80 0.821 5.375 4.413
213 2 068548 - 213 2 300001 3.79 0.889 5.375 4.778
214 2 000001 - 215 2 300001 3.79 0.889 4.857 4.318
216 2 000001 - 219 2 300001 3.79 0.889 4.571 4.064
Author:  ridenrace6 [ Sun Mar 31, 2013 12:27 am ]
it should be a 3:78 1st if its stock, which is stronger than the 3:80 1st gear, pretty sure only the early (up to 71 or 72 I think) 3 ribs had the 3:80 1st
3:80 has a 10 tooth main shaft gear and a 38 tooth pinion shaft gear
3:78 has a 9 tooth main shaft gear and (If memory serves me right) a 34 tooth pinion shaft gear
im sure maddog or eric debord on this site can verify
Author:  jesse [ Sun Mar 31, 2013 1:01 am ]
Thanks all im looking into a gear stack I wanted to go 4.25 first but dont think weedle sells it anymore the lowest is a 4.11 is that gonna still be alot lower than the stock
Author:  kevin f [ Sun Mar 31, 2013 8:37 am ]
the 4.11 will work good with a tall tire.
Author:  jesse [ Sun Mar 31, 2013 5:19 pm ]
ok good now when i do the gearstack do i keep the 456 in
Author:  kevin f [ Sun Mar 31, 2013 8:28 pm ]
I would its stronger and if its still to tall of a gear you can always do a 5.42 later.
