PostPosted: Fri Mar 29, 2013 9:00 pm
Can anyone tell what ring and pinion ratio this transmission should have by the numbers?
Is there another method to tell with the engine installed?
PostPosted: Fri Mar 29, 2013 9:52 pm
Check Eric Debolds web site I think he has the side case numbers listed
PostPosted: Sat Mar 30, 2013 11:36 am
We need letters from this location to answer your question.
PostPosted: Sat Mar 30, 2013 2:06 pm
The letters there are DU.
I found this site with codes and ratios:
http://rjes.com/html/gearbox_types.html
Looks like it should be 4.86:1
PostPosted: Sat Mar 30, 2013 4:33 pm
Just an FYI the 094 trans are 5 speeds. Most of the Vanagon side and mid shifts are still an 091 4 speed.
