It is currently Mon May 04, 2026 2:26 am
PostPosted: Mon Mar 18, 2013 6:44 pm
I am thinking about putting a VW jetta motor in my buggy, with a vanagon trans-axle. The question, is there any other VW bellhousing that I can swap in, so that I don't have to buy an adapter plate from Kennedy eng.?
Any help you guys could give me wold be great, Ethan
PostPosted: Mon Mar 18, 2013 7:07 pm
Its on here somewhere. Passat posted about it on here.
PostPosted: Mon Mar 18, 2013 7:15 pm
wont a diesel bellhousing work?? also did you read this forum??
http://www.thesamba.com/vw/forum/viewto ... 68&start=0
PostPosted: Mon Mar 18, 2013 7:29 pm
http://www.woodsbuggy.com/index.php?opt ... ellhousing Talk to passat i also read that all 4 cylinder watercooled bell patters are the same
PostPosted: Mon Mar 18, 2013 7:35 pm
Yep that's it
PostPosted: Mon Mar 18, 2013 7:36 pm
Thanks for the help guys. Davidk, I looked at the link, but I think that guy already had an adapter plate. I know that most of those water-cooled VW engines are the same. I am not very fimilar with the vanagon trans, what all do I need to know?
The motor is coming out of a 1999 VW jetta, if that helps.
Is there anywhere I can find a diesel bellhousing,that is reasonable, or even a whole trans? Close to Western Pa would be better.
PostPosted: Mon Mar 18, 2013 7:51 pm
Thanks again guys.
I am still unsure, if they are an exact match, the 1999 jetta, and the regular vanagon.
Dave, David or anybody know for certain if they are an exact match? I am going to have to buy a trans, so I have to give my buddy a year, code, or model number for the trans.
I have never worked on a Vanagon, thats why I don't completely understand.
PostPosted: Mon Mar 18, 2013 8:49 pm
Pm Passat he knows all VW water cooled
