It is currently Mon May 04, 2026 2:32 am
PostPosted: Tue Jan 29, 2013 1:22 am
Just like title says anybody got any or whole trans ? 260 706 1769 nick
PostPosted: Tue Jan 29, 2013 9:32 am
nose cone or Vanagon?
PostPosted: Tue Jan 29, 2013 4:55 pm
Either is ok
PostPosted: Wed Jan 30, 2013 4:51 pm
Nose cone and early 83 side shift Vanagon use the same one. From late 83 on mid shifts, use a different pinion shaft due to the reverse gear being on the tail end of the shaft.
PostPosted: Thu Jan 31, 2013 7:36 pm
Either ring and pinion will work . On the 094 we just cut off the reverse gear and it works in 091 so either is ok with me
