 Post subject: 6 rib machine work?
PostPosted: Sun Dec 09, 2012 7:37 pm
Where is a good place to get the pinion bore steel sleeved on my 6 rib case? Hopefully someplace within a couple hours of NE Indiana.
Kenric
 Post subject: Re: 6 rib machine work?
PostPosted: Sun Dec 09, 2012 8:37 pm
any good machine shop should be able to do anything.
PostPosted: Sun Dec 09, 2012 10:15 pm
I think you will have to send that to weedle or long enterprises on the west coast.
PostPosted: Sun Dec 09, 2012 11:08 pm
Thanks for the input. I was hoping to find someone more local though. I will send it to Weddle if I cant find someone closer.
Kenric
PostPosted: Mon Dec 10, 2012 12:08 am
this place did a case for a ridding buddy of mine, i think its in cali also though
D.K. machining & fabrication 562-864-9618 or 310-864-9618 (this is for sleeving and gusseting of the case)
PostPosted: Mon Dec 10, 2012 12:56 am
I think the place Chris said is the guy that does Weddles cases . Last time I checked he only charged 95.00 to bore and sleeve pinion. 562-864-9618.
