| Axle length help- opinions http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=14460 |
| Author: | gasman [ Sun Dec 09, 2012 7:37 pm ] |
| Post subject: | Re: Axle length help- opinions |
To choose between one or the other I'd take a 1/4 inch off end of the 17-1/2 axles.I had a set that I had to cut like that and I also machined it back a 1/4 inch on the inside to allow the axle to still plunge in the cv. Chad |
| Author: | Psycho Alpha [ Sun Dec 09, 2012 7:46 pm ] |
gasman wrote: To choose between one or the other I'd take a 1/4 inch off end of the 17-1/2 axles.I had a set that I had to cut like that and I also machined it back a 1/4 inch on the inside to allow the axle to still plunge in the cv. Chad Thanks Cool so I did it right..... That should not be a problem, I have several machinist friends |
| Author: | fortydegnorth [ Mon Dec 10, 2012 9:09 am ] |
Doesn't look like you have the seal installed on the drive flange. If it measures 17.25" without the seal I'd say you will be closer to 17" with the seal. If you take the .25" away the 16.75" axles seem like they would almost be perfect. Even if it gives you 3/8" play it won't hurt anything. Just my $.02 |
| Author: | MadMike [ Mon Dec 10, 2012 12:37 pm ] |
Best make sure the stub axle is in the arm correctly. Be sure the bearing is up against the inner face in the housing and the spacer is in. fortydegnorth wrote: Doesn't look like you have the seal installed on the drive flange. If it measures 17.25" without the seal I'd say you will be closer to 17" with the seal. If you take the .25" away the 16.75" axles seem like they would almost be perfect. Even if it gives you 3/8" play it won't hurt anything. Just my $.02 The seal doesn't take up any space just the spacer the seal rides on. |
| Author: | Psycho Alpha [ Mon Dec 10, 2012 12:59 pm ] |
The bearing is all the way in and snap ring. And have the spacer on a the stub axle so I think 17" is solid Thanks |
