 Post subject: 6 rib questions
PostPosted: Tue Oct 23, 2012 10:24 pm
What parts from a 6 rib case shift(water cooled) are useable in a 6 rib aircooled (nose cone shift 1982)?
I have access to a water cooled 091 trans (minus ring and pinion and case) was wondering if the parts were worth having for an aircooled 091.
Kenric
 Post subject: Re: 6 rib questions
PostPosted: Fri Oct 26, 2012 10:31 am
I dont think anything is. If you cut reverse off the pinion shaft, you can use the ring and pinion in a nose shift.
PostPosted: Fri Oct 26, 2012 7:52 pm
Thanks for the info, but I cant make myself cut off a real reverse gear. I guess that I will pass on the deal.
Kenric
