It is currently Mon May 04, 2026 10:24 pm
PostPosted: Fri Sep 07, 2012 9:34 pm
im putting together a 2054. if i put in some stronger diff gears and main shaft with a weddle first will it hold up?
PostPosted: Fri Sep 07, 2012 10:01 pm
What size tires do u run. Are you going to put a
4 spider diff in it and what kind of riding do you do
Trail or hill climbs
Everyday is a naterday!!
PostPosted: Sat Sep 08, 2012 12:10 am
If you're going to put all that money in it, why wouldn't you just pick up an 091 for $400 somewhere?
PostPosted: Sat Sep 08, 2012 12:39 am
Go up to Canada and get a side shift 5 speed with a 483 and a 411 1st and 233 2nd.The final drive multiplied will pull like a 526. A 486 5 speed will pull like a 530.Lots a meat in that trans.
PostPosted: Mon Sep 10, 2012 7:59 am
What is this 5 speed you're describing? I've never heard of it. Sounds interesting to me, especially if 5th is an overdrive. I could use that for the street in my buggy and still have a solid 1st and 2nd. Is it an 094?
PostPosted: Mon Sep 10, 2012 11:27 am
This.....
OR, just take the several thousand dollar trip to canada to hunt for a trans. That would make much more sense! :lol:
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Mon Sep 10, 2012 6:18 pm
I know a couple guys that are running a 3 rib with weddle stuff and they have been tough as nails. I myself run a 5 rib with all weddle gears and a 5.38 ring and pinion. Mine has worked great until yesterday, I broke a tooth off a spider gear. Where I broke it at any tranny built would have broke. I say build it, it will hold fine. I have a very hot 2386 against mine and it takes it.
PostPosted: Mon Sep 10, 2012 10:48 pm
It is an 094, has a lower 1st gear added to the nose area next to the reverse gear, no overdrive gear.
Same as a syncro 4wd trans, just the pinion shaft is shorter and does not couple to a front diff.
PostPosted: Tue Sep 11, 2012 7:39 am
Destroyed a built one in 2 races on the back of a 2.1 :(
PostPosted: Fri Sep 14, 2012 12:10 pm
it all depends on the driver!!! I have seen v-8's pushing 3 ribs and hold up, and I've seen 1600's break 6 ribs.
PostPosted: Mon Sep 17, 2012 8:21 am
i think im gonna baby the one i got in there if i cant afford one within the winter time. My dad keeps tearing the diff outta 3 ribs, he has a 1915 with a stage 2 clutch. so idk if its the way he drives or what. lol
HEY RACEBUG WHEN YOU GETTIN THAT WOODSBUGGY TO WELLSVILLE :lol:
PostPosted: Mon Sep 17, 2012 8:58 am
soon i hope!! This past weekend was my first trip of the year :roll:
