 Post subject: input shaft trimming
PostPosted: Sat Aug 18, 2012 1:38 am
I have a three rib that I plan to bolt to my 1600. I heard that the input shaft needs to be trimmed. Is this correct any tips or specs to check? Thanks guys!
Without failure there is no success. We must be allowed to fall so we learn a better way to get up.
 Post subject: Re: input shaft trimming
PostPosted: Sat Aug 18, 2012 4:59 am
I've had a couple and never had to do anything. I've always bolted right up. Never had any problem.
PostPosted: Sat Aug 18, 2012 11:06 am
that's 091 and up.(6 rib).High speed a 1/2 inch, then cone shape a 1/16" so the motor will slide on easy. Put a tiny bit of high temp grease on your gland nut needle bearings.Don't pick up the trans or let a loose motor hang off on the imput shaft.A bad bent shaft can make the trans pop out of gear.
