It is currently Tue May 05, 2026 2:52 am
 Post subject: which car trans?
PostPosted: Sun Jun 24, 2012 1:55 am
its been a while and i cant seem to remember where i found or saved the info but im looking for the info on which car tranny that can can be used for fixing the gearstack in a 3 rib tranny?
im thinking its the ones with one side cover that will work and seems like somebody told me as long as it had the big pinion nut insted of the the 4 bolts they would work?
 Post subject: Re: which car trans?
PostPosted: Sun Jun 24, 2012 6:23 pm
call mr. farley..841-7147..ive seen him busting them apart for the gears, he knows what will interchange
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Mon Jun 25, 2012 3:13 pm
Did you find out? And will they work in a 5 rib?
PostPosted: Mon Jun 25, 2012 6:16 pm
The Samba says car transmission with only one side cover.
PostPosted: Mon Jun 25, 2012 7:29 pm
It should be the 388 car transmition if it only has one side cover
PostPosted: Mon Jun 25, 2012 8:58 pm
Single side plate car has the best [widest] 1st gear, and same 15 tooth reverse gear as 5 rib.
PostPosted: Tue Jul 24, 2012 4:14 pm
There are 2 different mainshafts used in 3 ribs. They both have 10 tooth first gears, but one has a bigger mainshaft that goes through the bearing under the nosecone. You could just measure the shaft, but if you take the nosecone off all you have to do is look at the shaft. The smaller shaft has a concave washer behind the snap ring..the "big" mainshaft does not. SO, if yours has the smaller mainshaft, then you can use parts from older "AH" code transmissions, but NOT the later "AT" and most single side cover car transmissions, because they have the bigger mainshaft. (Again, take the nosecone off of the car transmission and see what it has). If your 3-rib has the bigger mainshaft, you are in luck as then you can use the later style car trans components, especially 1st gear (it has 9 teeth.MUCH stronger them the 10 tooth). As for swapping both late and older car trans parts into a 3 rib, some things work, some dont, so it is easier to just match the car trans to whichever 3 rib you have. If you need any more help, just ask..
ericdebord@windstream.net
Eric
