| cross shaft bushings http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=13645 |
| Author: | kernal1984 [ Fri May 11, 2012 12:30 pm ] |
| Post subject: | cross shaft bushings |
I replaced the cross shaft bushing with poly ones and now my clutch is freakin stiff as a board and when i let off the pedal it takes a min to engage and sometimes i have to tap the pedal till it moves and engages. is this gonna get better with time or what? |
| Author: | Odyknuck [ Fri May 11, 2012 12:33 pm ] |
| Post subject: | Re: cross shaft bushings |
Yea it will probably lossen up. Did you grease the bushings? |
| Author: | kernal1984 [ Fri May 11, 2012 12:41 pm ] |
yeah i greased em but they were super tight and then it sat for 3 months so prob shot myself in the foot letting it sit that long thanks ody |
| Author: | Odyknuck [ Fri May 11, 2012 1:57 pm ] |
AH! So it sounds like your leg and the bushings are in need of some excersize! Better start pushing that pedal buddy |
| Author: | RaceBugg1098 [ Fri May 11, 2012 3:18 pm ] |
I never tried them in the cross shaft, but i hate those poly bushings in anything I have ever used them in. If they were better, dont you think vw would have used them? I would find some bronze or brass ones to try. |
| Author: | kernal1984 [ Fri May 11, 2012 9:53 pm ] |
man i hate to have to pull the motor to change that stupid thing but i put a pipe on the arm today and worked for a while and its still the same as it was Where could i find some stock bushings? its a mid shift vanagon tranny would that be the same as a nose cone cross shaft bushing |
| Author: | RaceBugg1098 [ Wed May 16, 2012 12:29 pm ] |
Im sure most buggy trans places can get em, or go to the hardware store and get one with a bigger od and smaller id and find a lathe and make em. easy to make and cheap. |
| Author: | Odyknuck [ Wed May 16, 2012 2:27 pm ] |
McMasterCarr would be another good source for alloy bushings. You could add an extra spring on the cluch arm for awhile waiting for them to loosen up to avoid removing the motor. Food for thought! |
