| gear question http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=13234 |
| Author: | diamonddav [ Fri Feb 24, 2012 2:49 am ] |
| Post subject: | gear question |
what is this little gear?in behind the bell housing? part of reverse ,huh |
| Author: | ridenrace6 [ Fri Feb 24, 2012 3:54 am ] |
| Post subject: | Re: gear question |
i think you are correct, whats the problem with it? |
| Author: | RaceBugg1098 [ Fri Feb 24, 2012 10:38 am ] |
reverse idler gear. |
| Author: | bige70chevy [ Fri Feb 24, 2012 2:29 pm ] |
thats the gear i chipped a tooth or two off at haspin...ruthless and toothless! |
| Author: | diamonddav [ Fri Feb 24, 2012 2:48 pm ] |
theres a circlip that holds this gear on. if this gear falls off your not goin to have reverse, correct? im thinking thats what happened to my tranny cause no reverse but all forward gears , and periodically a bangin like a small gear being tossed around inside the case off of the differential gears. im hoping it didnt tear up the diff. gears and i can put the gear back on and save the tranny |
| Author: | Rick [ Fri Feb 24, 2012 4:12 pm ] |
diamonddav wrote: theres a circlip that holds this gear on. if this gear falls off your not goin to have reverse, correct? im thinking thats what happened to my tranny cause no reverse but all forward gears , and periodically a bangin like a small gear being tossed around inside the case off of the differential gears. im hoping it didnt tear up the diff. gears and i can put the gear back on and save the tranny if thats the case your the luckiest guy in the world |
| Author: | Eric DeBord [ Sun Feb 26, 2012 7:15 pm ] |
Since you broke a couple of teeth off (I assume reverse slider gear-15 tooth), then most likely you damaged the case where the idler shaft goes through. Look on the front side and see if the shaft moves sideways and/or if you see any cracks on the housing where it comes through. If so, case is junk. If not, you were lucky! |
