 Post subject: building a 002 5rib
PostPosted: Sun Feb 05, 2012 10:45 pm
ok i bought a 002 5 rib what does it need to hold up to abuse of being a 2cnd gear tranny besides changing first and second. i only want to build this once so let me no
 Post subject: Re: building a 002 5rib
PostPosted: Sun Feb 05, 2012 11:30 pm
The 5 rib:
1.Has 4.86 r&p ,strongest stock r&p in the 002 series.
2.Need thrust plate,used to better hold mainshaft bearing in place. $12
3.I'd also add a 1/8 in. steel plate between the bellhousing and maincase to help prevent breaking of maincase.
4.Wide flange chromoly pinion nut. $40
5. Torsional input shaft. $168
6.Steel shift ball. $5
7.A real vanagon 4-spider diff. Must have! $350 shipped.
8. Hand pack 1st gear bearings instead of using the caged bearings. $20
9. Add more weld to clutch cross shaft or get a heavy duty one.
If you plan on climbing in 2nd gear, I'd probably put a 5.38 r&p in it, they're usually pretty cheap and easy to find.Refer to # 1.$265
If you could find a 5.42 for the 002,you'd be very lucky, they are very rare. $345
You might want to consider changing 3rd gear also, there will be quiet a difference between 2nd and 3rd when you change to that lower 2nd, especially if you like to drag race.
PostPosted: Mon Feb 06, 2012 12:06 am
thanks that was really helpful how many teeth does the 5.42 ring gear have
PostPosted: Mon Feb 06, 2012 12:09 am
Maddog wrote:
The 5 rib:
Basically hit mine on the head, If you do this it will be tough.
PostPosted: Mon Feb 06, 2012 9:28 am
I just finished rebuilding a 'bama trans that came in a buggy a fella up here got a year or so ago. It is a 6-rib with everything maddog just wrote and a sleaved pinion bore. it HAD a 5.86:1 ring and pinion in it that didn't hold up to the 2387 I sold him, so I put a stock 4.57:1 back in. I had never seen anyone mill down the bellhousing to put in that 1/8" mount instead of welding ears on it. Pretty cool!
PostPosted: Mon Feb 06, 2012 12:04 pm
No milling required, dowels still fit in bellhousing fine, bolt holes in plate are drilled for close clearance for all bolts and dowels going through it.
PostPosted: Mon Feb 06, 2012 12:38 pm
what is the stock 1st gear in a 091 6 rib and what ring and pinion would it have.
PostPosted: Mon Feb 06, 2012 1:15 pm
six ribs are 4.57:1 the gears are about the same as an 002 as far as their ratio.
PostPosted: Mon Feb 06, 2012 1:57 pm
Stock 1st gear 3.78,2nd 2.06 same in 5rib,6rib, and most 3ribs.
Some of the early 3ribs had a 3.80 1st gear, but essentially all the bus trannies in the USA have the same 1-4 ratios.
They are some that have like a 4.11 and 2.33 but I believe they were European models only, very rare.
R&P
3rib:5.38 and very few rare 5.42
5rib: 4.86
6rib nose shift: 4.57
6rib: side shift in nosecone or in main case: 4.57,4.83,4.86,5.42,5.50,5.83,and 5.86.
3rib vanagon side in nose shift:5.86
They're probably some very rare like 5.14 used in some industrial applications that vw made.
PostPosted: Tue Feb 07, 2012 12:40 am
thanks for all your help mad dog do you no whats the highest 1st gear you can get with the 2.46 2cnd.
PostPosted: Tue Feb 07, 2012 1:32 am
3.44 in 091 trans
3.11 in 002 trans
PostPosted: Tue Feb 14, 2012 10:25 pm
Is this the one that is fairly weak ?
PostPosted: Wed Feb 15, 2012 12:18 am
It's the weakest, I know of.
