It is currently Mon May 04, 2026 1:04 pm
 Post subject: gear ratio calculator
PostPosted: Thu Jan 26, 2012 2:47 am
this may not be the best avaible but heres a few thats fairly simple
http://et-studios.com/motorsports/gears/gears.html
http://www.apexgarage.com/tech/gear_ratios.shtml
http://www.currieenterprises.com/cestor ... ulator.htm
http://www.cargister.com/calculator-gear-ratio
and here is a couple of r & p calculators
http://www.csgnetwork.com/rnggrpinioncalc.html
http://www.currieenterprises.com/cestor ... arCalc.htm
PostPosted: Sun Feb 26, 2012 7:26 pm
Quote:
Stock 1st gear 3.78,2nd 2.06 same in 5rib,6rib, and most 3ribs.
Some of the early 3ribs had a 3.80 1st gear, but essentially all the bus trannies in the USA have the same 1-4 ratios.
They are some that have like a 4.11 and 2.33 but I believe they were European models only, very rare.
R&P
3rib:5.38 and very few rare 5.42
5rib: 4.86
6rib nose shift: 4.57
6rib: side shift in nosecone or in main case: 4.57,4.83,4.86,5.42,5.50,5.83,and 5.86.
3rib vanagon side in nose shift:5.86
They're probably some very rare like 5.14 used in some industrial applications that vw made.
PostPosted: Sun Feb 26, 2012 7:59 pm
This one is more intricate - it takes drag figures, engine torque, etc, and lets you map out the acceleration figures for your car, or run them side by-side with another car for comparison:
www.vimulator.com
Good for doing comparisons between gearsets too:
http://www.vimulator.com/#/v4/drag/12090+12091
