It is currently Mon May 04, 2026 2:18 am
 Post subject: 3 rib bus
PostPosted: Sat Jan 21, 2012 12:37 pm
hey guys i hve a 3 rib bus trans, when i put it in reverse it makes a really bad noise when i let out of clutch, so basically i thinh the sychos are out do you know anybody close by bardstown that can fix it or do you guys know whats it worth, thanks guys
 Post subject: Re: 3 rib bus
PostPosted: Sat Jan 21, 2012 12:56 pm
What is the size of that saturn engine you are running. May be a bit much for the 3 rib to handle.
PostPosted: Sat Jan 21, 2012 1:30 pm
It sounds like you have broken reverse gears. There are no syncros to go bad. As Nitro stated with the power you have it would be a good choice to go with a 5 or 6 rib,maybe even a mid shift 6 rib if you don't mind a little work gettin it in there. The reverse setup in those is HUGE.
PostPosted: Sat Jan 21, 2012 1:35 pm
Describe sound?
If it is kinda howling while backing up, just be easy on it.
If it's jerking, clunking or you can feel it when backing up, then yes you need it fixed.
Recommend Eric Debord in Mt. Olive,Ky, he is about 130 miles from you.
#1 vw tranny rule never spin tires while in reverse.
PostPosted: Sat Jan 21, 2012 3:47 pm
after aaron went through my 3 rib i can burn rubber in reverse ...its hooked to a lsx454r
PostPosted: Sat Jan 21, 2012 5:21 pm
hopefully you didn't kill 2nd also. reverse meshes with 2nd. when it goes it can take 2nd also. If rev only not to bad to fix. Still probably flat rate to tear down. $150 +parts around here. Good luck.
PostPosted: Sat Jan 21, 2012 6:15 pm
thanks guys, my saturn motor is a 1.4l its only 126 hp, the trans makes a clunkin sound reverse is out wont move at all, but 1234 works fine
