Need some pics of side shift slave cylinder please
http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=12926
Author:  giveitagallon [ Mon Jan 09, 2012 10:13 pm ]
Post subject:  Need some pics of side shift slave cylinder please
Was wondering what you side shift guys have come up with for mounting a aftermarket slave cylinder on a side shift .
Thanks for any help !
Jason
Author:  dink2275 [ Mon Jan 09, 2012 10:25 pm ]
Post subject:  Re: Need some pics of side shift slave cylinder please
i havent seen one in awhile but i dint remember it being any different than a 6 rib. i got a new buggy coming on day this week i can get a pic then it has a side shift in it.
Author:  Terry fryer [ Tue Jan 10, 2012 2:17 am ]
Use a slave saver do a google search
And u have to drill and tap 2 holes but its easy I have done it on 3 diffrent ones
Author:  reno2165 [ Tue Jan 10, 2012 2:27 am ]
does your tranny shift towards the front or a mid shift? i run a 483 mid shift and the stock slave cylinder and mounting bracket work great.. its easy to bleed and inexpensive
Author:  Eric DeBord [ Thu Jan 12, 2012 8:01 pm ]
VERY true. After running a cnc slave for years, I decided to try the factory push style slave. The difference is night and day. I even had an extended arm and the factory setup is still a LOT easier to push. Use factory and you will be convinced. No more binding, bypassing, leaking, hard to pull slave cylinders!
Author:  buggiejunky [ Thu Jan 12, 2012 8:56 pm ]
Jason i use a stock slave and bracket works great been there three years without a problem
Author:  giveitagallon [ Thu Jan 12, 2012 11:30 pm ]
Thanks for the help guys , I'm going to stick with the stock setup and just put new parts on .
Author:  ImmortalSoul219 [ Sat Jan 14, 2012 9:14 am ]
What stage clutch and pressure plate were you running?
Im running the cnc setup with stage 2 and its a nice firm pedal but not that bad.
