6 rib problem
http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=12755
Author:  badbrad [ Sun Dec 11, 2011 3:34 pm ]
Post subject:  6 rib problem
I have a early model 6 rib and it jumps out of gear when i push the clutch anybody know what this is.
Author:  badbrad [ Sun Dec 11, 2011 3:48 pm ]
Post subject:  Re: 6 rib problem
It pulls fine but it only jumps out when i push the clutch in :?
Author:  passat2800 [ Sun Dec 11, 2011 5:54 pm ]
Do you mean as you release the clutch?
Author:  badbrad [ Sun Dec 11, 2011 10:51 pm ]
No because it will pull fine its just like if your coastin with the clutch in it pops out of 1st gear. Or maybe it is when i release the clutch but when i put it back in first it pulls just fine. I dont know what the deal is.
Author:  Maddog [ Mon Dec 12, 2011 7:52 pm ]
Check tranny mounts for movement and shifter adjustment, or you've got a bad syncronizer.
Author:  badbrad [ Mon Dec 12, 2011 8:47 pm ]
Ok thinks ill look into it
