It is currently Mon May 04, 2026 1:04 pm
 Post subject: 6 rib problem
PostPosted: Sun Dec 11, 2011 3:34 pm
I have a early model 6 rib and it jumps out of gear when i push the clutch anybody know what this is.
 Post subject: Re: 6 rib problem
PostPosted: Sun Dec 11, 2011 3:48 pm
It pulls fine but it only jumps out when i push the clutch in :?
PostPosted: Sun Dec 11, 2011 5:54 pm
Do you mean as you release the clutch?
PostPosted: Sun Dec 11, 2011 10:51 pm
No because it will pull fine its just like if your coastin with the clutch in it pops out of 1st gear. Or maybe it is when i release the clutch but when i put it back in first it pulls just fine. I dont know what the deal is.
PostPosted: Mon Dec 12, 2011 7:52 pm
Check tranny mounts for movement and shifter adjustment, or you've got a bad syncronizer.
PostPosted: Mon Dec 12, 2011 8:47 pm
Ok thinks ill look into it
