It is currently Mon May 04, 2026 1:04 pm
PostPosted: Mon Nov 14, 2011 11:49 pm
PostPosted: Tue Nov 15, 2011 12:11 am
Nice. Austin and I put a 483 5speed in his back in '05 and it has been problem free.They have 411 first, 233 2nd etc.Europe and Canada is where to get them.I'd really like to see how they look inside aswell.Thanks for the pics!
PostPosted: Thu Nov 17, 2011 8:12 am
looks good from what i can see. you putting in weddle gears?
PostPosted: Thu Nov 17, 2011 10:02 am
steeper ring n pinion set,new pinion bearings,super diff and a few other recomended upgrades.
PostPosted: Thu Nov 17, 2011 11:41 am
I broke a few side shifts with my V6 Buick a long time ago so I put a home made 1/8 piece of aluminium between the bell housing and case on Austins buggy in '05 and he has never broke. I did that because the case and bell housing would have a large stretched crack in the lower rt corner when I would shear the pinion teeth.What do yall think?
PostPosted: Thu Dec 15, 2011 10:04 pm
Well Dave,
I'm taking your advice, but thinking about using steel instead.
I was banging on a 5ft ledge a couple of weekends ago and broke the pinion in my 091, case cracked just as you described.
Was your piece just cut to fit around the inside edge of the case, or was it pretty much solid with just an opening for the ring gear to pass through?
