It is currently Mon May 04, 2026 11:12 am
 Post subject: 3 rib revrese problem
PostPosted: Sat Oct 15, 2011 9:48 pm
So it goes into reverse and moves,but as u press in the clutch rolling backwards it kind drags or stops like something is binding!! Need some ideas on what it could be!
PostPosted: Mon Oct 17, 2011 5:42 pm
Check your pinion nut and you mainshaft bearing under the nosecone can cause that.
PostPosted: Mon Oct 17, 2011 7:29 pm
Cool thanks
PostPosted: Wed Nov 09, 2011 7:17 pm
Pinion bearing is shoot
PostPosted: Thu Nov 10, 2011 12:07 am
why dont you get it fixed? there is a guy name Brian in Ohio that fixes transmission. then you will know what you have. maybe someone will read this and tell you his info.
PostPosted: Mon Nov 14, 2011 2:30 am
Op is almost a month old but I think the Brian you want is at Drews off road 1888 go drews
PostPosted: Mon Nov 14, 2011 7:59 pm
x2
