It is currently Mon May 04, 2026 9:31 pm
 Post subject: 091 question
PostPosted: Fri Aug 26, 2011 9:44 am
the first 091 i took apart had a 4th gear thrust washer, the second one did not. Should it have one also or did they come either way thanks
 Post subject: Re: 091 question
PostPosted: Fri Sep 09, 2011 8:45 pm
You CAN use a thrust washer with a bearing that does not have one built into it, but I dont think these bearings have the notch in it for the half moon key.. correct? Anyway, the 6-ribs never came out with the thrust washer.. someone probably did not have the right bearing and did it that way.
