trans question
http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=12124
Author:  greenrail [ Tue Aug 02, 2011 10:58 pm ]
Post subject:  trans question
im trying to turn a side shift 6 rib into a tail shift only using the main case. but the side shift case is not drilled and tapped for fill plug. does any body know what size tap i need to use on the case?
Author:  Maddog [ Wed Aug 03, 2011 8:43 am ]
Post subject:  Re: trans question
I'd just tap it for a 3/4 pipe plug.
Author:  RaceBugg1098 [ Wed Aug 03, 2011 8:52 am ]
second that! I assume your using an early nose side shifter and not the water cooled style.
Author:  greenrail [ Wed Aug 03, 2011 6:03 pm ]
thanks for the help guys
Author:  Eric DeBord [ Sat Aug 06, 2011 9:26 pm ]
I think it is 24m X 1.5. But you can also use a 1 inch hole saw and rubber "freeze" plug. Unless you want to pay 80 bucks for the tap like I did, lol
