It is currently Mon May 04, 2026 12:28 am
 Post subject: Shifting Question
PostPosted: Sun Jul 10, 2011 8:43 pm
Started installing my tranny yesterday(side shift in nose cone) and i think i figured out my linkage but the way ive got it figured my 1st is lower left 2nd is upper left 3rd lower right 4th upper right and reverse is all the way left and back.
standard shift has 1st upper left and reverse all the left and up right?
is the lock out for reverse on the shifter gonna screw me or what?
 Post subject: Re: Shifting Question
PostPosted: Mon Jul 11, 2011 11:06 am
anybody???
PostPosted: Mon Jul 11, 2011 12:11 pm
My side shift (water cooled) shifts like a normal bus trans, except reverse is next to first instead of second
PostPosted: Mon Jul 11, 2011 12:30 pm
Does a sedan shift the same as a bus trans?
Where is your 1st at race bug?
PostPosted: Mon Jul 11, 2011 12:44 pm
im pretty sure racebugg said his was
R - 1 - 3
.....2 - 4
and the "standard" pattern for all the "older" vw's is
.....1 - 3
R - 2 - 4
PostPosted: Mon Jul 11, 2011 12:50 pm
Thats right! :mrgreen:
PostPosted: Mon Jul 11, 2011 5:04 pm
Nice diagram that helped :D
The way I'm doin my linkage mine will look like this
... 2. 4
R. 1. 3
I don't think that'll be a prob If you said older stuff reverse was lower left thanks for the input 8)
PostPosted: Mon Jul 11, 2011 6:27 pm
... 2. 4
R. 1. 3
Not sure how you have your linkage attached, but it sounds like you have the arm mounted above the rod sticking out of the tranny. If you flip it over so the arm is below the shift rod it will correct you problem.
PostPosted: Mon Jul 11, 2011 6:46 pm
Look at the black piece of the linkage, If i was to rotate that 180 degrees so the silver arm was above the shift rod it would reverse the shift pattern. Hope this helps.
PostPosted: Mon Jul 11, 2011 6:55 pm
My shifter is in the nose cone and it almost touches the frame horn so i dont have a choice but to come up thanks anyways
ive got a stock vw shifter now what kind do you guys like and dislike?
I would like to stay around a 100 bucks
PostPosted: Mon Jul 11, 2011 8:19 pm
i had same trans in mine before and it shifted same way your saying yours does. shift pattern dont mean a thing. if its in gear then its in gear. plus it fun to watch people try to move it and they cant find first!
PostPosted: Tue Jul 12, 2011 6:39 am
i use the scat drag-fast shifter in anything vw i have
PostPosted: Tue Jul 12, 2011 10:47 am
I really like my drag fast, and u can't beat them for the money in my opinion
PostPosted: Tue Jul 12, 2011 12:18 pm
I used to run the drag fast and liked it, but since changed it to a stock shifter cut down, and the throw is much less.
PostPosted: Tue Jul 12, 2011 3:43 pm
Really... how is the feel when u do that? Is the stock shifter as tight as the drag fast as far as going from second to third gear?
PostPosted: Thu Jul 14, 2011 10:27 pm
2 of the guys i ride with theirs is backward its no problem as long as it dont bother you
