It is currently Mon May 04, 2026 12:29 am
 Post subject: CV Bolt
PostPosted: Fri Jun 10, 2011 8:35 pm
I have a stock car trans with original bolts in them. I cant find the right tool to remove them. Are they, Allen, Torx, or what ever else there may be. Also what size would be a big help!!!!!!
Thanks again,
Dieseltechy360
Without failure there is no success. We must be allowed to fall so we learn a better way to get up.
 Post subject: Re: CV Bolt
PostPosted: Fri Jun 10, 2011 9:47 pm
they are either allen or the stupid star bit. Pair of vise grips will help ya get the old junk ones out. then after they are out throw them across the garage and forget them lol THen go buy all new allen head bolts along with the allen socket for them.
"IT IS WHAT IT IS"
PostPosted: Fri Jun 10, 2011 10:01 pm
its a 8mm 12point bit autozone sells them in a 4 pack all vws use this type of bolt just different sizes
PostPosted: Fri Jun 10, 2011 11:45 pm
its either 6mm allen or 8 mm 12 point,,,take a small flat screw driver and clean it out and u can see what it is,,,,,by the way the 12 point is alot better,,the allen wrench sucks,,,
PostPosted: Sat Jun 11, 2011 6:26 am
They are acually called "triple square" 8mm
PostPosted: Sat Jun 11, 2011 9:39 am
^Bi-Hex :wink:
PostPosted: Sat Jun 11, 2011 2:02 pm
why you say that i allways like my allen heads better, i kept busting those damn 12 point socket bits :? :roll:
PostPosted: Sun Jun 12, 2011 10:07 am
all my allen heads got sloppy,probaly cause i use a small 18 volt dewalt impact,,,lol,,that will do it every time
