| Can it be done? http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=11760 |
| Author: | kernal1984 [ Fri May 20, 2011 7:00 am ] |
| Post subject: | Can it be done? |
I've go a side shift 091(not mid shift in the case but on the nose cone) Can it be converted to nose shift with a donor tranny? I've looked aronud on the forums here and can't seem to find a definite answer |
| Author: | kevin f [ Fri May 20, 2011 7:13 am ] |
| Post subject: | Re: Can it be done? |
Yes it can be done. Thats what I have now and it works great. You just have to use the mid section from the nose shift. I would recomend letting someone do it that has done it before. Chuck Jones is my choice of tranny builders. |
| Author: | RaceBugg1098 [ Fri May 20, 2011 10:47 am ] |
In theory all your doing is putting your gears into another 091 transaxle. Your doing the same thing if you use the guts out of it to repair a broken 6 rib. |
| Author: | kernal1984 [ Fri May 20, 2011 12:05 pm ] |
Any recommendations for a tranny guy close to southern IN |
| Author: | RaceBugg1098 [ Fri May 20, 2011 12:19 pm ] |
I know of a fella near merango that does them, but dont have his # or know if he would even do it. |
| Author: | kernal1984 [ Fri May 20, 2011 1:14 pm ] |
RaceBugg1098 wrote: I know of a fella near merango that does them, but dont have his # or know if he would even do it. Any way to find out? any other suggestions, davis racing is about 2 hrs away |
| Author: | kybuggy1 [ Fri May 20, 2011 1:30 pm ] |
kernal1984 wrote: Any recommendations for a tranny guy close to southern IN Chuck is in Lodon, KY but I'm down there just about every other week, minimum once a month. I'd be happy to carry it to him for you. his number 606 224 9921 Larry |
| Author: | kernal1984 [ Fri May 20, 2011 2:12 pm ] |
kybuggy1 wrote: kernal1984 wrote: Any recommendations for a tranny guy close to southern IN Chuck is in Lodon, KY but I'm down there just about every other week, minimum once a month. I'd be happy to carry it to him for you. his number 606 224 9921 Larry Thanks for the offer i might take you up on that when i get a donor tranny rounded up. if you live in louisville how long does it take you to get to london ky |
