It is currently Mon May 04, 2026 7:45 pm
 Post subject: Can it be done?
PostPosted: Fri May 20, 2011 7:00 am
I've go a side shift 091(not mid shift in the case but on the nose cone)
Can it be converted to nose shift with a donor tranny?
I've looked aronud on the forums here and can't seem to find a definite answer
 Post subject: Re: Can it be done?
PostPosted: Fri May 20, 2011 7:13 am
Yes it can be done. Thats what I have now and it works great. You just have to use the mid section from the nose shift. I would recomend letting someone do it that has done it before. Chuck Jones is my choice of tranny builders. 8)
PostPosted: Fri May 20, 2011 10:47 am
In theory all your doing is putting your gears into another 091 transaxle. Your doing the same thing if you use the guts out of it to repair a broken 6 rib.
PostPosted: Fri May 20, 2011 12:05 pm
Any recommendations for a tranny guy close to southern IN
PostPosted: Fri May 20, 2011 12:19 pm
I know of a fella near merango that does them, but dont have his # or know if he would even do it.
PostPosted: Fri May 20, 2011 1:14 pm
Any way to find out? any other suggestions, davis racing is about 2 hrs away
PostPosted: Fri May 20, 2011 1:30 pm
Chuck is in Lodon, KY but I'm down there just about every other week, minimum once a month. I'd be happy to carry it to him for you.
his number 606 224 9921
Larry
PostPosted: Fri May 20, 2011 2:12 pm
Larry
Thanks for the offer i might take you up on that when i get a donor tranny rounded up.
if you live in louisville how long does it take you to get to london ky
