It is currently Mon May 04, 2026 12:28 am
PostPosted: Sat Apr 30, 2011 3:44 pm
Show me your linkage if your running a side shift
I need some ideas
 Post subject: Re: Side shift linkage
PostPosted: Sat Apr 30, 2011 7:23 pm
Here is a thread on the weddle linkage that I am using and some pics of rail1914 making his own off this design.
http://www.woodsbuggy.com/index.php?opt ... 12&t=10772
PostPosted: Sat Apr 30, 2011 8:36 pm
I talked with Willie the other day and Southern Buggies has a new design for side shifts that looks pretty cool. Give Southern Buggies a call.. Look in sponsors for the number..
PostPosted: Sat Apr 30, 2011 9:19 pm
My side shift is in the nose and I thinks yourns is in the case
Thanks though :)
PostPosted: Mon May 02, 2011 8:05 am
If yours shifts in the nose, dont even bother with it. All you have is 6-rib, nothing better. not worth the trouble
PostPosted: Mon May 02, 2011 9:40 am
Gonna run what i got until i can afford better, thanks for the opinion though.
How hard is it to come by a "good" nose shift trans with damaged gears or R&P so i could convert what i got?
PostPosted: Tue May 03, 2011 10:07 am
Some one has to be running one of these :!: :!: :!: :!:
PostPosted: Tue May 03, 2011 2:44 pm
it cost bout the same to convert it over to nose cone shift as it does for a good shifter linkage,,,they are good trannys,,jus a stock 4;56
PostPosted: Tue May 03, 2011 3:26 pm
i dont have any pics of my old set up and is long gone now but i used a cable shifter from a cavalier the used the good aftermarket throttle cables for cables (the ones in the sheathing) and made a simple braket to do on the trans. sorry dont have any pics
PostPosted: Thu May 05, 2011 12:24 am
http://www.woodsbuggy.com/index.php?opt ... =7&t=11280
