It is currently Mon May 04, 2026 12:28 am
 Post subject: 5.50 RING & PINION ?
PostPosted: Fri Apr 08, 2011 2:06 pm
6/33 ring. & pinion. would this be a strong or weak ?
 Post subject: Re: 5.50 RING & PINION ?
PostPosted: Fri Apr 08, 2011 4:40 pm
More info- 5.50 ring & pinion ? Is it A 3 rib 5 rib 6 rib ? Could it be a 5.38or 5.42 ? What is 6/33 ? teeth on ring & pinon?
PostPosted: Fri Apr 08, 2011 5:21 pm
091 6 tooth pinion 33 tooth ring.
PostPosted: Fri Apr 08, 2011 5:42 pm
strong pinion, weak ring,,that many teeth on the ring and they get narrow
PostPosted: Sat Apr 09, 2011 9:52 am
thats and odd tranny i would like to see pics,run the number on the side of it see what it came out of
PostPosted: Sat Apr 09, 2011 8:20 pm
Diesel 1984 and newer, side shift in main case.
PostPosted: Sun Apr 10, 2011 7:39 am
with the 6 tooth pinion the teeth are a lot heavier than a 7. just didnt know if that would be better or not
