It is currently Mon May 04, 2026 7:14 am
PostPosted: Wed Mar 30, 2011 9:49 pm
has anybody tried a 5.86 in a stock gear stack?
PostPosted: Wed Mar 30, 2011 10:01 pm
Tiny pinion head. Junk.
PostPosted: Wed Mar 30, 2011 10:06 pm
cant find a 542 so does any body have any other ideas this is a machined down 094
PostPosted: Thu Mar 31, 2011 10:32 am
Why not just run the stock? It is the strongest.
PostPosted: Thu Mar 31, 2011 4:17 pm
For tails riding I run a 4.57 r/p & a 4.38 first & 2.46 2nd 1.72 3rd 1.18 4 Drews built trans .The 5.86 pinion is week
PostPosted: Thu Mar 31, 2011 8:26 pm
just trying to gear the trans down the cheapest way i can im open to any ideas
PostPosted: Fri Apr 01, 2011 10:18 am
The Best way to do it would be to keep the 4.56 and regear the trans to what you want. A 1st and 2nd gear set wont cost much more than an after market R&P, and you will be setting your self up for future improvments in stead of breaking it when you build a bigger motor or go with more aggressive tires or what ever. :mrgreen:
PostPosted: Tue Apr 05, 2011 10:53 pm
thanks for the info. the problem im having is what gears 2 run for 1st and 2nd at the moment i have a set of cut 35 boggers but i would like to be able 2 run 35,s in first and 31 v-treads in second . my motor is pretty strong above 2 grand with a stock 6rid and the 35s thanks
