It is currently Mon May 04, 2026 12:28 am
 Post subject: 3 RIB TRANS
PostPosted: Thu Mar 17, 2011 3:12 pm
I'm running a 3 rib with a super shifter and pretty much have to adjust for reverse every time I ride. 1st-4th gear's shift fine. Anyone had this problem or an idea on what the problem could be?
 Post subject: Re: 3 RIB TRANS
PostPosted: Thu Mar 17, 2011 8:42 pm
this may or may not help, but i set my shift linkage in the reverse gear! ive always heard set your linkage with the trans and shifter in the reverse gear, if reverse is rite the rest will be. this has always worked for me :wink: but there are variables, like shifter or linkage wear
lets just ride
PostPosted: Thu Mar 17, 2011 10:59 pm
Thanks, that will prbly help. I'll try that tomorrow.
Also, this evening I noticed that the shift shaft sticking
Out the nose cone has a lot of flop in it. Could it be a bushing wore out
Causing some of my headache ?
PostPosted: Thu Mar 17, 2011 11:20 pm
yes! any slop in your linkage can cause a problem
lets just ride
PostPosted: Sat Mar 19, 2011 12:04 am
Bushings and a better adjustment
Fixed it. Thanks !
PostPosted: Sat Mar 19, 2011 12:43 am
Fixed it. Thanks !
your welcome! glad i could help!
lets just ride
