| CLUTCH FOR THE STREET http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=11244 |
| Author: | bluebuggy [ Thu Feb 10, 2011 10:15 pm ] |
| Post subject: | CLUTCH FOR THE STREET |
My buggy will be on the street 80% of the time im going to run a ecotec. I was going to order a Kep. stage 2 with a 6 puck but Kennedy told me they would not run that on the street at all (acted like it would rip my head) they said i should run some HD stock type. what are some of you guys running on the street. thanks |
| Author: | davehix [ Thu Feb 10, 2011 10:25 pm ] |
| Post subject: | Re: CLUTCH FOR THE STREET |
A stage 2 and a cush lock disc shouldnt be to bad. |
| Author: | chris38375 [ Thu Feb 10, 2011 10:50 pm ] |
stage 2 with a 6 puck is what i would run,i think a stage 2 with a stock clutch or cushlock would slip,ive ran both with a vw motor and cushlock would slip in higher gears,with that ecotech u gonna need some good stuff,i run a 6 puck brass clutch and they are perfect,,nothing like a 4 puck |
| Author: | Firebug [ Thu Feb 10, 2011 10:54 pm ] |
I have had my best luck with 6 pucks. but that is all woods. I liked my stage 2 when I ran it too. |
| Author: | mudnut [ Thu Feb 10, 2011 11:22 pm ] |
buddy has ecotec in light buggy he runs in woods 99%. he has stage 2 pressure plate and a cushlock. for the most part it works great. would think is fine on street unless your trying to set new wheelie record |
| Author: | bluebuggy [ Thu Feb 10, 2011 11:23 pm ] |
chris38375 wrote: stage 2 with a 6 puck is what i would run,i think a stage 2 with a stock clutch or cushlock would slip,ive ran both with a vw motor and cushlock would slip in higher gears,with that ecotech u gonna need some good stuff,i run a 6 puck brass clutch and they are perfect,,nothing like a 4 puck what does it feel like on some blacktop or have you had it on some. I had a stage 1 with a cushlock with a 1915 on the street it was ok but did lockup fast and hard would it be about the same or harder?? |
| Author: | bluebuggy [ Thu Feb 10, 2011 11:27 pm ] |
mudnut wrote: buddy has ecotec in light buggy he runs in woods 99%. he has stage 2 pressure plate and a cushlock. for the most part it works great. would think is fine on street unless your trying to set new wheelie record I would like it to stand up nice but not from every LIGHT |
| Author: | chris38375 [ Fri Feb 11, 2011 10:26 am ] |
it feels jus like a stock clutch,it dont shake like a 4 puck,i think u will like it,u wont have to buy another clutch for a long time |
| Author: | lngtrvl2332 [ Fri Feb 11, 2011 10:48 am ] |
Outfront Motorsports told me it was pretty much a toss up. 6 puck will never slip but is like a light switch on pavement. You have to get used to EXACTLY where your clutch engages or you'll stall on street a lot. They told me stock style would work great (for a while) but hard starts and hill climbs would kill it eventually with that much power. Damned if you do... Damned if you don't... |
| Author: | Firebug [ Fri Feb 11, 2011 12:35 pm ] |
I think you will like the 6 p,,,do you have cable pedal or hydraulic? mine is cable |
| Author: | kybuggy1 [ Fri Feb 11, 2011 1:26 pm ] |
I ran a 6 puck for a while with a stage 4. It seemed to grab great. Just a little chattery on an easy launch, nowhere near as bad as a 4 puck, but dont think I'da liked it on the street. Worst thing about it to me was in a tight spot had to slip clutch repeatedly and it smoked it a little and was never the same. Once a stock disc cools (as long as you dont flat out roast it) it will grab again like normal. I liked kushlok better, switched it back. A sprung center stock or kushlok disc shouldnt give u any chatter at all and will be very smooth, and with a stout pressure plate it should hold the 170(??) or so hp of the ecotec. If you run hydropedals, use the smallest m/c you can find (prolly 5/8) and the stage 4 is not hard to push. Bad thing about a stage 4 on a vw is its hard on your thrust, but dont think you have to worry about that with a w/c engine. JMO |
| Author: | davehix [ Fri Feb 11, 2011 5:10 pm ] |
kybuggy1 wrote: I ran a 6 puck for a while with a stage 4. It seemed to grab great. Just a little chattery on an easy launch, nowhere near as bad as a 4 puck, but dont think I'da liked it on the street. Worst thing about it to me was in a tight spot had to slip clutch repeatedly and it smoked it a little and was never the same. Once a stock disc cools (as long as you dont flat out roast it) it will grab again like normal. I liked kushlok better, switched it back. A sprung center stock or kushlok disc shouldnt give u any chatter at all and will be very smooth, and with a stout pressure plate it should hold the 170(??) or so hp of the ecotec. If you run hydropedals, use the smallest m/c you can find (prolly 5/8) and the stage 4 is not hard to push. Bad thing about a stage 4 on a vw is its hard on your thrust, but dont think you have to worry about that with a w/c engine. JMO
| Author: | ironhorse [ Fri Feb 11, 2011 6:09 pm ] |
get a sprung hub 6 puck with the stage 2 and youll be fine |
| Author: | hyde [ Fri Feb 11, 2011 7:08 pm ] |
I ran a stage 2 & 6puck for about 100 mile on back road 1 day & was fine . But you my like a stage 3 & cush lock . |
| Author: | bluebuggy [ Fri Feb 11, 2011 7:44 pm ] |
I have a hydraulic pedal and im really thinking about the 6 puck but will the will it be harder on my trans and cv's then the cush lock would. |
| Author: | tw9294 [ Fri Feb 11, 2011 8:31 pm ] |
bluebuggy wrote: My buggy will be on the street 80% of the time im going to run a ecotec. I was going to order a Kep. stage 2 with a 6 puck but Kennedy told me they would not run that on the street at all (acted like it would rip my head) they said i should run some HD stock type. what are some of you guys running on the street. thanks Thats what kennedy recomended for me also so i went with it. Its been fine for me so far. 3 trips to wellsville,1 trip to wheelers some play time at a friends,drunken flat tracking at a holloween party and a thousand or so street miles last summer. I'm happy with it so far. |
| Author: | ridenrace6 [ Sat Feb 12, 2011 3:45 am ] |
id recommend a stage 2 kennedy pressure plate and a kush loc clutch disk but thats jmo |
