It is currently Mon May 04, 2026 12:28 am
PostPosted: Sun Jan 09, 2011 6:31 pm
the mount on my torsion was bent bad so im replaceing it and wondering if there is anything i should know before welding it up !
thanks jason ImageImage
PostPosted: Sun Jan 09, 2011 7:07 pm
That's not blood in that pic is it,you might need a band-aid,lol.now might be the time to add an adjustable torsion in it.or if you wanted to tilt your tranny like a lot of these guys do.Chad :mrgreen:
PostPosted: Sun Jan 09, 2011 7:24 pm
Bolt your plate to the trans and then install it and tack weld plate. That way you know exactly were it goes
PostPosted: Sun Jan 09, 2011 7:30 pm
yep , good eye chad the buggy made me bleed my own blood :evil: im putting bags on the buggy so the torsion will not be used .
thanks ody thats exactly what i was thinking but wanted to make sure you guys are not clocking it or something for more engine clearence .
PostPosted: Mon Jan 10, 2011 1:13 pm
Well I did drop the front of mine to get clearence for the Subie motor.. Also if you deside to use a mid shift Vanagon trans in the future it will not fit without relocating the mount close to the torsion.
