 Post subject: Popping out of first
PostPosted: Sat Jan 01, 2011 5:49 pm
I tore out reverse Thanksgiving weekend. I got that fixed, but now it keeps coming out of first gear. It sure made our trip today a short one. Any ideas?
 Post subject: Re: Popping out of first
PostPosted: Sun Jan 02, 2011 2:33 am
dont you run a 3 rib??? if you do just pick up another, they are pretty cheap :wink:
lets just ride
PostPosted: Sun Jan 02, 2011 1:51 pm
Start in 2nd gear... :twisted: :twisted:
PostPosted: Sun Jan 02, 2011 3:12 pm
could had not got the shifting forks adjusted right inside the tranny,did u put it in a jig to set up r,1st,2nd,3rd,and 4th,,if u did that it jus could be ur shifter not adjusted in the right place
PostPosted: Sun Jan 02, 2011 3:58 pm
time to switch to a side shift and all your prob will be gone for good
PostPosted: Sun Jan 02, 2011 5:21 pm
u can break anything
PostPosted: Mon Jan 03, 2011 3:48 pm
yep, sounds like time to re-jig!
PostPosted: Mon Jan 03, 2011 5:27 pm
very true :lol:
PostPosted: Mon Jan 03, 2011 5:34 pm
You can drill a hole in the side of the case at the shift forks. Then you can adjust the depth of first gear. I think eric debord's site explains where to drill the hole. when you are done just install a rubber freeze plug in the hole. Or tear it out and re jig it.
PostPosted: Mon Jan 03, 2011 6:45 pm
When we tore it down the pinion bearing had came apart. It is a 3 rib, but they are getting harder to find local, and the money to buy one is getting harder too.
PostPosted: Tue Jan 04, 2011 10:25 pm
If you never set it back right then tear it down and fix it.cheaper than tearing it up.check out Eric debord site.there is a link to it on the home page.you may want to try and go that route.or put a bungee cord on it :shock: lol.Chad :mrgreen:
PostPosted: Wed Jan 05, 2011 12:01 am
:idea:
