Shifter locks up
http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=10796
Author:  bryant82106 [ Fri Dec 03, 2010 12:03 pm ]
Post subject:  Shifter locks up
I have a stock swingaxle transaxle on my buggy and if i let it sit for about a month the shifter basically locks up and is hell to move but once i get it loose and ride it a little it shifts perfectly smooth. As long as i drive it every week or so it does fine but i was wondering if it is the bushings in the nose cone causing this problem. Ive had a few buggies before and never had this problem before??
Author:  passat2800 [ Fri Dec 03, 2010 12:59 pm ]
Post subject:  Re: Shifter locks up
Has your trans ever been sunk in a creek and the oil floated out of the vent hole and replaced with some water?Just a guess.Just enough water to make it sweaty inside.Got a trans from a huricane Mobile Al junk yard that was gaulded up this way.
Author:  Roy [ Fri Dec 03, 2010 6:44 pm ]
Water infiltration is usually the cause.
Author:  bryant82106 [ Sat Dec 04, 2010 3:17 pm ]
thanks fellas...i was just wondering what i could do...
Author:  ruttrider [ Sat Dec 04, 2010 4:11 pm ]
Drain the trans and try new oil.
Author:  john [ Sat Dec 04, 2010 7:16 pm ]
drive it once or more time's a week!!!!! thats a good reason to get out and play!!
Author:  bmoore [ Sun Dec 05, 2010 3:16 am ]
:mrgreen:
Author:  bryant82106 [ Sun Dec 12, 2010 11:29 am ]
I tried draining the oil and putting fresh oil in last spring and the old oil was black and didnt look like it had any water in it. I have never taken the nose cone off where the shifter has bushings that i understand dont ever see any oil. Has anyone ever changed those bushings and if i pull it off are there alot of moving parts in the nose cone i need to look out for?
Author:  chris38375 [ Sun Dec 12, 2010 3:52 pm ]
all the moving parts do get oil,theres 1 brass bushing in nose cone but dont think it will cause ur problem,,,drain ur oil and look at it 1st,try puttin a gallon of cheap motor oil in it and running it for a day or so to see if it helps
