| Cost of changing a Swingaxel to IRS? http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=10167 |
| Author: | Evan [ Sun Aug 29, 2010 1:14 pm ] |
| Post subject: | Cost of changing a Swingaxel to IRS? |
Just wondering if you could give me a rough estimate. Thanks |
| Author: | MickeyMouse [ Sun Aug 29, 2010 2:13 pm ] |
| Post subject: | Re: Cost of changing a Swingaxel to IRS? |
Wow.... That is a really tough quesiton. There are so many things that will drastically change the price. It really comes down to how much do you want to spend. You can easily spend $500 - $3000+ depending on options.. Here are some questions to consider.. Are you planning to cut the swing axle torsion out and install a completely new IRS torsion or modify the Swing Axle? Do you plan to run stock trailing arms or go with 3x3 or 3x2 arms? Do you have a Transmission already? Car or Bus? Depending on the answers above, you will need Axles, CV Joints, Stub Axles, Shocks and Mounts There are a bunch of other stuff to consider but lets start with these questions. |
| Author: | Evan [ Sun Aug 29, 2010 2:47 pm ] |
MickeyMouse wrote: Wow.... That is a really tough quesiton. There are so many things that will drastically change the price. It really comes down to how much do you want to spend. You can easily spend $500 - $3000+ depending on options.. Here are some questions to consider.. Are you planning to cut the swing axle torsion out and install a completely new IRS torsion or modify the Swing Axle? Do you plan to run stock trailing arms or go with 3x3 or 3x2 arms? Do you have a Transmission already? Car or Bus? Depending on the answers above, you will need Axles, CV Joints, Stub Axles, Shocks and Mounts There are a bunch of other stuff to consider but lets start with these questions. I was going to cut the Swing Axel out 3x3 arms (most likely) I would need to buy a transmission. Would probably go with a 6rib and add a super diff later. Do you think it would be worth it to change? |
| Author: | Buckmaster [ Sun Aug 29, 2010 3:19 pm ] |
100% worth it.Your going to gain a huge amount of strength and like MM said,many more options for suspension.Your best bet would be to go with 2x3's or 3x3's and at least bus joints.As for cost |
| Author: | chris38375 [ Sun Aug 29, 2010 7:24 pm ] |
i wouldnt cut the torsion out jus use the one thats in there and use the weld on pivots and cut ur spring plate to fit the ur trailing arms,save u some time and money |
| Author: | MickeyMouse [ Sun Aug 29, 2010 10:28 pm ] |
As for costs.. Trailing Arms, Axles, CVs, $1000 6 rib Tans with Dif $700 Brakes and Shocks $600 These are very rough costs. Better parts will cost more or you can find used for less. At the end of the day, you will spend around $2500 to upgrade to something strong and reliable. |
| Author: | Evan [ Sun Aug 29, 2010 11:04 pm ] |
Thanks for the rough estimate. I'm possibly headed up to Michigan later this week to look at a Buggy for sale. The ONLY thing I'm not crazy about on it is that it's a swingarm. But I can run the swingarm for a year or so. I'm not going to be doing any major hill climbs or anything anyways. But when I upgrade I want to upgrade to something durable enough for an Ecotec, which is my ultimate goal. But this will be a nice starter buggy. And it's pretty nice and clean for the cost. I'lll be sure to post pictures etc. up if I buy it. |
