| subaru stock bell housing adapter!!? http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=10092 |
| Author: | volksdude2010 [ Tue Aug 17, 2010 12:39 pm ] |
| Post subject: | subaru stock bell housing adapter!!? |
ok i was wanting to know who all runs the stock subaru bell housing adapter to the vw bus tranny and how much you paid and where i could possibly get one |
| Author: | Stevo [ Wed Aug 18, 2010 7:39 am ] |
| Post subject: | Re: subaru stock bell housing adapter!!? |
http://cgi.ebay.com/ebaymotors/Subaru-V ... ccessories |
| Author: | Odyknuck [ Wed Aug 18, 2010 12:24 pm ] |
If I was starting from scratch, the Bell housing would definatly be the way I would go. Not real fond of having an additional plate between the trans and Engine. In my case it would have given me an additional 5/8" for the badly needed Turbo plumbing. It allows you to us the Inexpensive Subaru starter and does away with the VW clutch design. You can buy a Subaru clutch setup that can handle 500HP. |
| Author: | volksdude2010 [ Thu Aug 19, 2010 12:21 am ] |
well thx to the both of you i could get an adapter for cheaper than that i think i just picked up a subaru leagcey that runs and drives for a couple hundred bucks and was wanting to know my options does any one have one of the housings they wanna sell me a lil cheaper than that lol i have some money to play with but not much considering i still need other stuff to convert to subi |
| Author: | Stevo [ Thu Aug 19, 2010 8:43 am ] |
There a little on the new side and I havent seen any used yet. But if you think about it it worth it after you add up the adapter and starter with a good clutch. The bellhousing one you use the stock suby clutch starter wich are stronger and redily avalible. |
| Author: | RaceBugg1098 [ Thu Aug 19, 2010 12:16 pm ] |
i got the reg. adpt plate, flywheel and hardware for $440 from outfront. no complaints yet |
| Author: | volksdude2010 [ Thu Aug 19, 2010 11:55 pm ] |
can u you use the stock hydralic clutch pedal set up as with the bell housing do you know i seen the hydarlic on the one buggy build i would like to have hdarlic cause i know my brothers clutch you gotta stand on it because of the hd pressure plate and your foot gets tired real quick |
| Author: | Firebug [ Fri Aug 20, 2010 6:11 am ] |
There are good and bad on both adapters. The KEP is simpler but you add a half inch to the motor setback,,,not a bad thing though. I have the starter thing worked out. The VW diesel starter whizzes my 3.3. It's $75 on ebay or $125 for a Bosch at O'rielleys. Then a slight mod. I have great luck out of a KEP stage 4 PP and 6 puck disc. The more VW stuff you have on your buggy the easier it is to get parts on the trail. |
| Author: | rail1914 [ Fri Aug 20, 2010 7:38 am ] |
bigscott has the bell houseing and had alot of problems with it there are 2 different bell housings one that you looking at and one that uses a stock subaru tubro cluch and a vw hydo slave cyclender i thank it one is alot better look on buggy builds for bigscotts new stalker frame with turbo suby post |
