It is currently Mon May 04, 2026 3:55 am
PostPosted: Thu Oct 21, 2010 9:55 pm
i took scotts side shit apart today found shifter rod bushing broke but this is what a side shift trans looks like in side Image
Imagethis pic is rev. gear it is one of the biggest gears in the transImage
PostPosted: Fri Oct 22, 2010 11:17 am
Thanks for posting the pics and pointing out the reverse gears. They were the main reason I went with the 84 and later Vanagon trans. I have seen so many guys blowing the reverse in the nose cone trans that I would never use one. I have used the reverse in my 2500# car backwards up hill!
PostPosted: Fri Oct 22, 2010 7:49 pm
one other thing i like about this trans is the shift forks are welded you dont have to ajust the forks and rev gear is in the nose not in the trans this trans seems to be alot simpler
PostPosted: Fri Oct 22, 2010 9:02 pm
I've got one of these sitting on my workbench at work that i want to fix and build. What sort of special tools or info do i need? Is there a trans build manual available,etc.
Thank You Tony
PostPosted: Fri Oct 22, 2010 9:38 pm
Try Long Enterprises for a manual. As I recall they also sell rebuild vids.
PostPosted: Fri Oct 22, 2010 10:26 pm
longs does have a vids and yes it does take about 3 to 4 hundos in special tools i havent seen one of these broke what is wrong with yours we thought there was something wrong with scotts so we took it apart what we found could have been fixed in the buggy butt every body i have talked to said they have not had one of these apart yet had to see in side :lol:
PostPosted: Sat Oct 23, 2010 8:21 am
Whines VERY loudly in 3rd and 4th. When i drained fluid it had metal shavings in it. The one i have in the car works ok except it will pop out of fourth if you don,t rest your hand on the shifter. That would,nt be so bad except i drive mine on the street. I have a turbo i would like to install at some point on my ecotec so i would like to repair/upgrade the one i have out and add a superdiff.
Thanks Tony
PostPosted: Sat Oct 23, 2010 8:51 am
sounds like 3,4 maine shaft bearing is going bad letting the gears meash two close as fore 4 gear it could a bad syco,shifter fork or a shifter rod bearing thats whats wrong with this trans. we are talking about a side shift right where the shifter is in the middle of the case not on the nose .if you can find a sideshift trans with the vin start with acw this trans has a factry superdiff
PostPosted: Sat Oct 23, 2010 1:13 pm
Yeah there midshift vanogon trannys. I was looking for acw code trans when i bought these. Bought noisy one for 350 and second one for 500. Hows that for luck? Bought two and they both have problems. The second one has been great otherwise. 5 trips in the woods and 1000+ street miles this summer. I,m the kind that would rather learn and build myself. I NEED to know how things work and in the long run its cheaper to do it yourself and you know exactly what you have that way. I have access to many tools and i'm willing to buy the tools i need. I,ve already spent tool money on two trannys that are'nt right.
PostPosted: Sat Oct 23, 2010 8:39 pm
true that longs is great help with tools and parts drews is allso great help the will give more info then longs .longs has great brake down pics on there web sight if i can be any help hit me up :D
PostPosted: Wed Oct 27, 2010 9:49 pm
i got a side shift tranny 5 speed, it has a 411 1st n a 233 2nd, but yeah reverse is massive, u aint gunna break it for sure. acw is the code of wut ratio it is gunna belike either a 4 diff or a 2 diff so watch out acw means 4 or 2 diff. u will never break a side shift, ive ran one for 4 years n put it through hell with the 38 in a half im turning. but yeah side shift is the way to go
the women r at the top of the hill
PostPosted: Thu Oct 28, 2010 12:09 pm
I have not been into a side shift any farther than installing a cromoly pinion nut and super diff. I have re-built plenty of nose shift bus transaxles. From what I understand, you dont need any special tool to do anything with a side shift other than a pinion nut socket (wich it looks like you already have). Unlike a nose shift tranny, the shift points are not adjustable, so there is no need for a jig. You just take it apart, replace parts and put it back together. Thats what weddle told me anyway.
PostPosted: Thu Oct 28, 2010 5:08 pm
your right thay are very easy no crazy spring in side to deal with just snap rings and gears i love them .acw does have 2 or 4 diff you are wright so guys watch out you are running a syncro 5 speed can you send me some pics of your set up i have been thinking of going to a 5 speed the gear ratio the 411 is awsome what year is yours
