It is currently Mon May 04, 2026 2:19 pm
 Post subject: 091 gear clearance
PostPosted: Wed Aug 04, 2010 6:25 am
Whats the most optimal 1st and 2nd gear thrust clearance?
Every man loves a set of TWINS especially sitting on a dragster
 Post subject: Re: 091 gear clearance
PostPosted: Wed Aug 04, 2010 10:05 am
how do u adjust the clerance between the two 1st gears
PostPosted: Wed Aug 04, 2010 10:21 am
I didn't think you could adjust any of the gears, just the pinion depth with those shims
PostPosted: Wed Aug 04, 2010 10:31 am
thats me i didnt either,the bearings dont move
PostPosted: Fri Aug 06, 2010 6:00 am
i was reffering to the amount of end play for each of the individual gears that are on needle bearings.
PostPosted: Fri Aug 06, 2010 10:15 am
the only shims i know of are behind pinion bearing,theres no way to do what ur talking about,that i know of,
PostPosted: Fri Aug 06, 2010 12:12 pm
your refering to the play between the gear and the syncronizer? it should have some slop in it.... thats how I measure it :mrgreen:
PostPosted: Wed Aug 11, 2010 5:35 am
091's do not shim the way type 1's do. The nut has no shims and end play should be ok without any shimming. I would guess .010 to .015 without looking it up. A little more probably will not hurt. I have never had a need to change the end play using either stock or Weddle gears and never had any problems. 3rd and 4th are the ones you usually have trouble with sometimes.
