It is currently Tue May 05, 2026 1:40 am
PostPosted: Mon Nov 30, 2009 7:38 am
Between my shifting rod and my nose cone, the coupling keeps loosening up. There are currently 2 little allan screws (one on top and one on bottom) that hold the coupling in place.
Is there a good way to keep these screws from loosening up?
I was thinking about drilling a hole through the nose cone shift rod and replacing the little allan screws with a nut and bolt. Your thoughts?
Thanks
PostPosted: Mon Nov 30, 2009 7:56 am
i lok tighted mine
PostPosted: Mon Nov 30, 2009 11:17 am
There should be a small hole in the set screws. Take a piece of wire and go through the small holes and around the shit rod and twist tight.
PostPosted: Mon Nov 30, 2009 11:22 am
I just read that it has allen heads screws.
This is what the set screw should look like for the wire.
PostPosted: Mon Nov 30, 2009 11:28 pm
Drilling a hole through is exactly what i did. Now i have a 5/16 nut and bolt and its GREAT! :D
