It is currently Sun May 03, 2026 5:09 pm
 Post subject: Black magic iron disc
PostPosted: Fri Jun 19, 2009 3:25 pm
Anyone ran one of these clutches? Its suppsoed to grab like a 4 puck but it is designed to slightly slip at first then heat makes it grab. (This all happens instantly I guess). They say stick with a stage 1 PP which is what I have. I need something better the new more power motor is killing the cushlock/ST1 PP combo.
"Lets go get stupid"
PostPosted: Fri Jun 19, 2009 5:38 pm
I've heard of em, I think alot of drag racers use em so it's not as hard on their drivetrain. I'm also curious how it'd do in the woods.
-Dakotah/koko
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Fri Jun 19, 2009 5:44 pm
use a 6 puck brass clutch,they work great
PostPosted: Fri Jun 19, 2009 6:52 pm
I know a guy that drag races with a BM disc and a Stage 1 or 2, depending on track conditions.
10.85 index full bodied pan car, turbo and a fair amount of HP.
Works for him........ :mrgreen:
PostPosted: Fri Jun 19, 2009 11:28 pm
I use a 4-puck and a stage 1 pp this combo works very well with the light buggies I am going to put in a stage 2 pp soon with a new clutch.
PostPosted: Fri Jun 19, 2009 11:48 pm
Never ran one but not sure if you saw this.
http://www.thesamba.com/vw/classifieds/ ... ?id=743370
LowBugget has the Black Magic Iron Discs.
The Black Magic Iron Disc will slip/hook. What it will do is slip at first, then build heat and grab ASAP! This all takes place in a mill sec and will help save your transmission. Unlike a 4-puck if it keep sliping you would toss it in the trash. With a Black Magic Iron Disc you can blast it with a sand blaster and bring it back to new! This is one of those performance parts that you will buy only once!
Recommended: Kennedy Stage 1 pressure plate.
(do not use or need a stage 2 with this disc. we have used this disc with stage1 and made over 270tq )
On Sale $139.99 each not $189 like some others!!!!
I wonder how long it lasts between having to sand blast it.
PostPosted: Sat Jun 20, 2009 9:02 am
Hey brad yea that where I was seeing them at LBC. I was wondering the same thing also about how long it I'll last between "cleaning". The 4 pucks break trannies I don't think I want one plus if you slip a puck disc and get it hot it's done. That's where I think this one might work good. Looks like it's going to be worth a try.
PostPosted: Sat Jun 20, 2009 2:50 pm
You should'nt have to slip the 4-puck clutch just rev then go, I think slipping the clutch kills them no matter what kind you have. They should'nt break transmissions either, it just depends on how the transmission is built, if you have a stock transmission and bus axles, maybe they will break, but so far, nothing yet.
PostPosted: Mon Jun 22, 2009 12:13 am
I agree. They are killer.
Grabs like a 4 puck, but you can slip it without the chatter.
With a stage 4 pp.
